Problem: Can I configure or preset Show in Mode in a file or a template?
I want,
Tutorial: Uncheck cursor movement layer and audio layer.
Demo: Check cursor movement layer and audio layer.
Can this be preset and done automatically? May be using Preferences or file properties or somewhere in AP.
Now, what happens is - visit every slide and check or uncheck respective layers which is tedious and time taking.
You can select an audio object/ a cursor path on the Canvas > select/ deselect the mode that you want to display/ hide. Then, right-click it > Apply to All Audio Objects/ Cursor Paths > Show In Mode:
