Hi team! How do I create button shortcuts and scroll through items in my presentation?
AP: 7.0
OS Windows 8.1
Thanks for advance!
Please use Key Stroke to handle shortcuts instead. You can define actions in its On Key Press event.
Regarding “scroll through items”, I guess that you are talking about navigating between buttons by pressing Tab. If so, you can set the Tab Order option in Properties > Interactivity > General for buttons.
Hi Dao!
Great! Only my Tab Order does not funcionality, it does not highlight the buttons.
Please select “Enable Visual Focus Indicator” in the Export To HTML5 dialog.
Dao, thanks you for your attention and readiness! It worked!
