Currently it would seem there is no capability to set a shape’s fill opacity, only the shape’s general opacity.
Reading up(Googled) it seem that setting a shape’s fill opacity is possible in code.
The goal is to create a shape where a solid border with no opacity and the fill to have some opacity applied.
Click the drop down arrow on the colour box you have highlighted and on the right hand side is a slider that allows you to adjust the transparency for the fill colour.
DOH! Can’t believe I missed that. Thanks @mackavi
