Setting "shuflle answers" and number of attemps for multiple questions
Hello there,
I use Active Presenter 9. I little bit sturuggle with setting properties for multiple slides. I have a lot of questions already created and I need to change the number of attemps for each of them and shuffle answer option. Is there any possibility how to do it for multiple slides? JavaScript of something else? Thanks a lot.
Hi Keri,
Currently, ActivePresenter 9 allows selecting each question to adjust attempts.
Regarding your request for multiple slides, this is about to be supported in version 10.
Thus, you can wait a bit more until version 10 is released and then test this feature to see how it goes.
Thank you in advance for your patience.
Please feel free to suggest other features if you have any.
BR,
Quynh Anh
