Screen recording duration is shorter than actual recording time (e.g., 30s recorded, output is 26s)
Hi everyone,
I’m running into an issue where the duration of my screen recordings doesn’t match the actual time spent recording.
For example: I record my screen for 30 seconds, but when I stop the recording, the resulting video in the timeline/output is only 26 seconds long (or even shorter). Parts of the recording seem to be missing or truncated.
  • Has anyone else encountered this issue?
  • Is there a known fix or setting I should adjust to resolve this (e.g., frame rate settings, hardware acceleration, or audio synchronization)?
Any help or insights would be greatly appreciated!
Thanks in advance!
Hi Dick,
Thanks for reporting the issue. I tried to reproduce it on my end using several different settings but I wasn’t able to get the same duration mismatch, so it may be specific to your setup.
A few questions to help narrow it down:
  1. Does this happen every time you record, or only occasionally?
  2. What are your machine specs (CPU, RAM, OS)?
  3. Could you also attach the ActivePresenter log file from a session where this occurred? You can find it by going to Preferences → Miscellaneous → View Log button, or by opening Explorer, typing %AppData%\ActivePresenter, and pressing Enter — the log file is named ActivePresenter.log in that folder. You can send the log file to: support@atomisystems.com
Thanks,
Thanh
No, I have encountered this multiple times as well. It is a very serious bug. It happens randomly, cutting off the end portion of a screen recording. To get around this issue, I usually record extra time at the end, but in my latest attempt, even that was not enough.
Thanks,
Ben
Hi Ben,
Thanks for confirming this happens randomly. To help us dig into this further, could you please share:
  1. Your system specifications (CPU, RAM, operating system/version).
  2. The ActivePresenter log file from a session where this occurred (ideally right after a reproduction). You can get it via Preferences → Miscellaneous → View Log, or from the AppData folder. Please send it to support@atomisystems.com.
Since this appears random/intermittent, having the log from an actual occurrence — along with your system specs — will really help us track down the root cause.
Thank you for your patience!
Thanh
Hi Dick and Ben,
Thank you for sending over the log file. A fix for this is on the way and will be included in the next release.
What causes it: when Direct3D capture is used, the last frames of a recording can be dropped if the screen content does not change at the end of the session. That is why it looks random — it only shows up when the final moments of the recording are static.
Until the fix ships, either of these workarounds should avoid it:
  • Turn off Direct3D in the recording settings before you record, or
  • Keep Direct3D on, but make sure something on the screen changes right before you stop — for example, switch to another window, record a couple of extra seconds, then stop.
Ben, this also explains why recording extra time at the end did not help in your latest attempt: the extra time only helps if the screen is still changing during it.
Thanks again for the report and for helping us track this down.
Thanh
Thanks, this helps a lot.
So, if I move the mouse randomly at the end of the recording, it will force it to capture to the end.
Ben
