Hello, when I make my project a scorm file with activepresenter, it causes problems on the inap browser side in the mobile app, the content gets stuck. What could be the cause of this problem?
This problem may be due to insufficient in-app browser performance. The solution we can offer is to check the content of the slide where you are experiencing issues then optimize it. Look for factors such as large image dimensions or file sizes, a large number of animations or resource-intensive effects like the shadow effect (on iOS only), green screen, and so on.
In case you need further assistance, kindly provide a more detailed description of the problem (e.g. images illustrating the issue) and share your project (.approj) along with its external data folder named in the pattern PROJECT_FILE_files (if any) with us so that we can investigate thoroughly. You can email us at support@atomisystems.com.
