On most objects in Active Presenter, we find the little yellow square to easily create rounded corners. We would love to see it also on the Drag and Drop question type.
Thanks for considering!
Hi Koen,
You can select multiple objects in a Drag-n-Drop question > select Format tab in the toolbar > select Change Shape > Rounded Rectangle:
Thank you. That’s the help I was looking for!
