Problem: Rotate tool become cut tool?
Saola Animate version: v3.0; OS: win10;
Bug report: Firstly you should open the sample project “boat-sea”.
Step1. add a built-in shape, for example, a rectangle or a circle.
Step2. choose “Rotate tool”, then drag its x-axis or y-axis or z-zxis,
then you can see the screencut below:
No matter rectangle or circle will be cut to half (visually),
but if I delete the background picture of this scene, everything seems OK.
Best regards,
Afei
