Dear support,
I have a presentation with a question pool. In order to check the questions with the subject expert I had the idea of exporting them to MS Word (the size of the pool and the number of the random slide match). Unfortuneatly in the output I do not see the questions but only the grey placeholder for the question pool.
My quick workaround would be to copy all the slides from the pool temporarily in the main presentation. However I wonder if there is a better way to achieve what I want.
Best wishes
Ludger
ActivePresenter version: 8.5.1
OS: Windows 10
