When I use the return key it acts as a button press and activates a random button.
If I’m too impatient when using my “text entry” object and the next one hasn’t appeared yet, I sometimes press the return key too soon. When I do that, the return key activates my restart presentation button.
I don’t want the return key to “press” a button. Is there a way to deactivate that?
When you press Enter, the button that currently has keyboard focus will be activated. This applies to both the buttons on the slides and the buttons on the player toolbar, and it is the standard behavior of buttons.
If you don’t want Enter to activate your Restart button on the slide, you can remove it from the tab order:
Select the Restart button.
In the Properties pane, open the Interactivity tab > General section.
Set Tab Order to None.
You can also enable the visual focus indicator, so you can see which button has focus before pressing Enter:
Open the export dialog for your output (for example, Export > HTML5).
In the Content section, select Enable Visual Focus Indicator.
