Problem: I am working on a module with dimensions 1920x1080 pixels. It is mainly intended for a desktop computer. But demands are emerging for it to also be fully compatible with iOS and Android tablets (horizontal display, not vertical).
I tried to transform the work done in 1920x1080 pixels into a responsive module, but the result is catastrophic. However, I used flex boxes.
Can you tell me which settings I should use, knowing that in the end I only need one setting (at least that’s what I think, but I may be wrong ).
Here is the setting I would like to use:
• Concerning the width of the module, the content must be able to adjust proportionally, automatically, very exactly as it already does with my module made in 1920x1080 pixels. All the content adjusts proportionally, there are no bugs, it’s perfect.
• Concerning the height of the module, you must first know that my slides contain 2 flexboxes with scrollable content. So I would like the flexboxes to adapt to the height of the browser window. And that the content of the flex boxes show more or less information, depending on the height enjoyed by the flex boxes.
I hope I have been as clear as possible in my explanations.
If so, can you tell me how to do it?
Thanks a lot for your help.
ActivePresenter version: 8.5.6
OS: MacOS 10.15.7
