Responsive Project Document
Ap 9 or Ap 10 I’m creating a responsive project and setting its content, but it’s not working stably; there are gaps on the left, right, top, or bottom of the screen. Is there any documentation that explains the detailed use of a responsive project?
If you’re experiencing gaps on the left, right, top, or bottom when creating a responsive project in ActivePresenter, we recommend reviewing the official documentation for detailed guidance on responsive design.
For version 10, please refer to the User Manual starting from page 32, which explains how to create and work with responsive projects, including layout setup and object behavior.
For version 9, you can consult the tutorials available on our Tutorials page or our YouTube channel.
Although the tutorials are made for version 9, the workflow and core concepts are quite similar to version 10, so they should still be very helpful.
