Resource search
Good evening everyone!
I would like to know if there is a method for quickly searching through the resources loaded in a project.
I have more than 100 audio files and should upload more, but I find it difficult to search for a particular file.
I spend so much time on it that I can no longer remember which file I was looking for, but this last problem is due to my age :joy:
Thank you very much for your work and help.
Best regards!
Good morning dear,
For your information, we’re working on this feature and will add it to the next major version of ActivePresenter.
BR,
Thank you from the bottom of my heart @PhuongThuy_Le :heart:
Good news, @Betty!
In ActivePresenter 10, you can now quickly and consistently find and replace resources across multiple slides using the Resources pane.
This makes managing and updating your project much faster and more efficient.
Just right-click the resource > select Find and Replace .
BR,
Thank you very much PhuongThuy_Le, I’m waiting to do the update because I see from the posts that it causes some problems, but when it’s more stable I’ll do it.
Best regards :pray:
