Reset attempts in text entry
Problem: Attempts do not reset
ActivePresenter version: 9.1.1
OS: Windows 11
I use two “Text Entry” objects in my slide. Both have a maximum of 6 attempts. After 3 attempts a hint is shown.
During presentation I can move back and forth between the previous and the current (slide with Text Entries) slide. If I solved only one of the Text Entries and move back to the previous slide, the Text Entry should be resetted. I got that with “Clear User Input”, but the attempts-counter is not resetting and I don’t find an option to reset the attempts. Is there a way to reset attempts as well?
Thank you and kind regards
The built-in attempt counter can’t be reset. As a workaround, set Attempts to Infinite for both Text Entries and count the attempts with your own variables:
  1. Create two number variables, e.g. attempts1 and attempts2 (initial value 0).
  2. Set both hints as Initially Hidden (right-click the hint > Playback > Initially Hidden).
  3. Add the built-in Disabled state to both Text Entries (Object States pane > Add State > Built-in States > Disabled).
  4. In the On Incorrect event of Text Entry 1:
    • Adjust Variable: attempts1 + 1
    • IF attempts1 >= 3, THEN Show Object (hint 1)
    • IF attempts1 >= 6, THEN Change State (Text Entry 1) to Disabled
    Do the same for Text Entry 2 with attempts2.
  5. In the slide On Load event:
    • Adjust Variable: attempts1 = 0 and attempts2 = 0
    • Change State: both Text Entries to Normal (before Clear User Input)
    • Clear User Input: All showing interactions
Each time the learner returns to the slide, the Text Entries are enabled and cleared, the hints are hidden again, and the attempts start from 0.
For more details on how to use Clear User Input in the slide On Load event, you can refer to these threads: How to retake quiz, Reseting the object state
Thanh
Hello, thank you very much.
This worked perfectly.
