Reset a text variable
Problem: My keypad has a CE (Clear Entry) button, to clear the entry of variable X1,X2 or X3.
I had to code the action with JavaScript code, because the standard AP ‘Adjust variable’ action, doesn’t allow you to adjust a variable with an empty value.
I think it should be simple to reset a variable to an empty value.
Thanks for looking into this.
Koen
Thank you for bringing this to our attention.
We’ll further investigate this case and try to improve user experiences.
Great day,
