After recording a video and exporting it, the cursor size is too small to see. How can I increase the size of the cursor before exporting so that cursor is visible.
When I select the video and the properties and ‘cursor’… the ‘cursor highlight type’ field is not available.
I figured out why the ‘cursor highlight type’ was not visible… I guess my screen is too small. I needed to scroll the pane over.
So I can get the ‘highlight’ to work fine.
BUT… the actual mouse image… the little arrow… is way too small when rendered. I use a high resolution screen and under OSX I set the mouse pointer image quite large. This increase seems to be lost when the render happens. Any more help?
