Problem: When recording a Software Tutorial I just need the mouse cursor path with a visible click action (yellow rhombus in the timeline). I don’t need the “Mouse Click_1” object so i have to delete it manually after recording. Is there a better way for my project?
The checkbox Mouse Click interaction activates/deactivates the rhombus as well as the mouse click object.
via batch operations it is a good way to remove mouse_click after the content is recorded. The conenient way for me would be a recording without mouse_click interaction. But when I uncheck it, i am also loosing the “rhombus” and therefore the “click” effect oft he cursor path.
