Recording Nvidia Broadcast Virtual Cam
Hi.
I would like to record the virtual webcam created by Nvidia Broadcast, but there’s no such device when selecting the device to use, while others software, such as Camtasia, do.
This means that it’ìs not a system issue, but an ActivePresenter issue.
Please, can you add this feature? (Or is it there a trick to record the virtual device?)
Thank you.
Stefano
Hi Stefano,
Hope that you’re well.
For your information, ActivePresenter only supports the new webcam API on Windows called Windows Media Foundation. Maybe the driver of Nvidia Broadcast only supports the old API (Windows DirectShow API), so it is not recognized by ActivePresenter.
Unfortunately, we don’t have a plan to support DirectShow since some of its features are deprecated.
Best regards,
