Recent projects cleared
Problem: The list of ‘Recent projects’ is sometimes cleared.
ActivePresenter version: 10.1.1
OS: Windows 11
Hi Koen,
This behavior is typically caused by the application window size rather than the list actually being deleted.
If the application window is resized or made too small, the “Recent” section will be hidden or cut off because the interface does not currently support a scroll bar for that specific area.
So, try maximizing the ActivePresenter window or manually increasing its height for the list to reappear.
BR,
Quynh Anh
Thanks! I did set my monitor to a lower Zoom percentage and it works fine now.
I’ll share it during my AP trainings!
