Is there a way to use a specific font that is not available by default in Active Presenter?
How to add redirection links from one slide to another? For example, I have added a Home button and few more buttons on a slide. I want the user to be redirected to the Home slide after clicking the Home icon on some other slide. How to achieve this?
Is there a way to add textual content on an imported video in a slide?
I am new to Active Presenter and need urgent help for a project. Kindly help with this urgently.
Yes, of course. Just download the font and install it on your computer. Once the fonts are installed on your computer, they will be embedded into ActivePresenter when you launch the app.
Using events-actions in ActivePresenter will help you achieve that. For example, select the Home icon > add On Click event > Go to Home slide action for your case.
Here are some tutorials for your reference. Please take time to read and learn how to work with ActivePresenter events-actions:
Yes, you can add closed captions to your imported video. Kindly refer to this tutorial for more details:
Besides, ActivePresenter allows you to add multiple languages to closed captions or convert text to speech, as well.
The attached written tutorials above also include video tutorials. Hope that they are helpful to you.
Feel free to ask if you need any assistance.
BR,
