Help please… I’m going crazy!!!
I’m preparing a drag&drop project, but the release areas aren’t working properly.
Only after several attempts do they accept the object.
I don’t understand this strange behavior…
See video to understand…
Can you please share the project file so we can check? You can delete other slides, just leave the slide which has the issue and email us at support@atomisystems.com.
An object will not receive mouse events if it has no fill and no line.
So please set solid fill for your drop targets.
If you want to make them transparent, you can set color opacity to 0.
