Problemi con il colore del testo delle risposte ai quiz
Problem: Anche se nello slide master il colore dei testi è bianco, quando importiamo il file .CSV dei quiz i testi delle risposte sono in nero.
ActivePresenter version: ActivePresenter 10.5
OS: Windows 10 Pro
Notes: Sarebbe poi possibile settare per tutte le domande non solo i tentativi e i punteggi ma anche il formato dei pulsanti i font e le dimensioni del testo delle risposte? Questo ci farebbe risparmiare tantissimo tempo.
Grazie mille.:slightly_smiling_face:
Hi Fabio,
Thank you for reporting this and for your detailed feedback.
Regarding the answer text color of questions imported from a CSV file, the question formatting can inherit from the Question Layout in the Slide Master. However, this applies to questions that are created or imported after the layout has been configured. Questions that are already in the project keep the formatting they had when they were created, which is why the changes did not appear on the questions you had already imported.
How to configure the formatting before importing your CSV file
If you want all questions imported from the CSV file to use the same formatting, you can configure the Question Layout in the Slide Master before importing the file:
  1. Go to View > Slide Master.
  2. Open the layout containing the Question placeholder.
  3. Configure the desired appearance, such as:
    • Answer text color
    • Font
    • Font size
    • Button formatting
    • Other available visual properties
  4. Close the Slide Master view.
  5. Import your CSV file.
We have verified that questions imported after the layout is configured use the formatting defined in the Question Layout. This allows the same visual formatting to be applied across different question types in the imported file, so you do not need to configure the appearance separately for each question type.
Regarding your suggestion about common question settings
Your suggestion about having common settings for questions is also supported through Question Settings and Slide Master.
Question Settings allows you to configure common question-related defaults for newly added questions, including Points, Attempts, and Question Layout.
The Question Layout controls the visual design of the question. These layouts can be customized through the Slide Master, including the appearance and placement of question text, answer choices, and buttons.
Therefore, if you want to configure a common appearance for different question types, you can use the Slide Master Question Layout. This is particularly useful for settings such as fonts, font sizes, answer text colors, and button formatting.
For more specific appearance defaults for individual question types, you can also use View > Object Settings. Object Settings maintains separate defaults for each question type, so it is useful when different question types need different formatting.
In summary:
  • Question Settings → common question settings such as Points, Attempts, and Question Layout.
  • Slide Master → common visual formatting for the Question Layout, including fonts, font sizes, answer text colors, and button formatting.
  • Object Settings → question-type-specific default appearance settings.
This means you can configure the common settings and appearance in advance and then import your CSV file, rather than having to format each imported question individually.
For more information, please see:
How to Work with Question Settings in ActivePresenter 10
How to Work with Slide Master in ActivePresenter 10
Best regards,
Thanh
