Problem: prez.slideTime(time) function stops going to the correct time when called again after calling prez.showSlideAt(index, time) and prez.slideTime(time) functions when slide is paused waiting for user input (e.g. a text box)
in trying to recreate the fault I’ve discovered it was only occuring on presentations I’d originally created in ActivePresenter 6, when a text box from activepresenter 7 is used the problem no longer occurs.
It works fine in my test though the text box is created in version 6.
Maybe it’s specific to your project.
If you still need help in this issue, please send your project to our support at support@atomisystems.com
