Preserve/remember "slides view" between saves/projects/re-load
The setting “Slides view” where you can choose “Slides in grid” is not preserved when closing Active Presenter. It would be good for this to save to the project, or as a system-wide setting, so the user doesn’t have to set this multiple times per day.
Thanks for reporting the problem. We will check and try to fix it soon.
