If I interrupt after any slide and then return, the system allows me to scroll back and forth between the slides already viewed, but if I finish all the slides, by exiting and returning, the system necessarily restarts me from the first slide, not allowing me to review a SCORM already view.
Doing some analysis I saw that the cmi.entry (cmi.core.entry) parameter is always set as “ab-initio” (AbInitio) instead of “resume”.
So is there a way to tell Activepresenter to generate SCORMs that at the end of the presentation communicate resume to the LMS instead of ab-initio in the cmi.entry variable?
I’ve responded to you in this thread: Una volta completato il corso, se voglio rivedere le slide già viste non mi consente di muovermi liberamente - #5 by Hang
Please check it for more information.
Thank you Hang, we’ll follow the other post.
