Saola Animate version: 3.1.3
OS: W10
I’m experience an odd glitch that I think started when I installed 3.1 several weeks ago.
When I’m building and I click on the position panel, it and the transform panel have frequently (not always) contacted. None of the other panels do this.
I’ve managed to recreate a simple example of this happening in the following screen cast:
Some possible extra things that might help:
- I think the issue may have something to do with the width of dock on the left side. If seems to happen if it is wide enough to show the units for the width / height.
- I think it started after the 3.1 update. I tried all the 3.1 versions and it kept happening. I use disk imaging software, so I restored my March backup that was using Saola 3.0 and it didn’t seem to happen.
Cheers.
