It would save a lot of time if you could just copy ALL parameters with a single click. Thanks !
You can select multiple objects to set their size and transform in the Properties pane.
Besides, Alignment Tools allow you to align elements:
Thanks for your kind reply. But I was thinking more about the position of an element in two different scenes. Maybe there is a quick way to do this that I am not aware of, If there is, please advise. Thanks a lot
Hi Carlos,
I’m not sure what you meant about “the position of an element in two different scenes” was.
If you want to copy & paste element(s) from one scene to another, you can copy the element(s), then use one of three options of paste (Paste/Paste Here/Paste with Animation) to paste.
If you want to show an element over multiple scenes, right-click the element and select Show Across Scene.
Please take a look at the Manual for more details.
It seems that I have not explained myself well. Imagine that you have 5 scenes and in each one a circle with a different number (all the circles with their different numbers are in the same position in each scene). If for whatever reason, I want to change the position of the circles afterwards, I want them all to be in the same position, a copy / paste button of the position would be very useful. Swish Max I had it indeed. In any case it is only a suggestion to see if you consider it. Thanks for your attention
Thank you for your information.
In this case, you have to do it manually.
We will take this into consideration if there are more requests from users.
