I have had a couple sets of Atomi Smart lights for a while. I have one bridge that controls the backyard and another bridge that controls the lights in the front yard. A while ago, my lawn mower cut the wire on my front light set. I contacted Atomi and they sent me a replacement section. Since then, I have not been able to get the front lights to connect. I have tried everything. Holding the reset button down 10 minutes. Uninstalling and reinstalling the front yard bridge. UnPlugging everything and letting them sit for a week. Nothing works. I cannot even tell if they are still getting power. Backyard bridge and lights still working perfectly. Any suggestions?
Hi - I believe you have found the wrong support community.
This is Atomi Systems which supports two software applications - ActivePresenter and Saola Animate.
Based on your request, you are likely looking for Atomi Smart.
I don’t have any experience with those type of lights or I would answer anyway but I would not want you to be waiting long for a solution here.
Best of luck to you.
Hi Cormac,
It seems that you connect to the wrong address. We do not sell Atomi Smart lights so we cannot support your case.
Thanks, @gregs for your prompt assistance.
Good day, guys
