Problem: I have set my Export Player settings so that users can skip to the next slide. The Next slide button appears but doesn’t work. Also, I can’t drag the marker along the timeline to a place further in the presentation. Am I doing something wrong?
ActivePresenter version: Version 8.5.7 - 64-bit build. (Released: 2022.05.16)
Regarding the Next slide button, please check again in the Player Settings window to see if you select None or Backward Only for Navigation mode.
That may the reason why your Next slide button is disabled.
In this case, just choose Free mode, instead.
About dragging the marker along the timeline and place in a new position, it also depends on the Navigation mode that you’ve selected.
And Free mode is recommended in this case.
