I have over 300 slides in a project, all of which have a different background image. To keep the project small, I do not merge the background with the slide but I keep a jpg as an object in the back. This seems to save roughly one Mbyte per slide.
My problem is that I use objects in the master to appear in all slides. Is there a way to put them in the front for each slide?
Thanks, Rolf
ActivePresenter Version: 8
OS: Win10
