AP not detecting microphone and in privacy settings AP is not listed.
Can you please share the log file of ActivePresenter? To view the log:
- In Start Page, click Preferences (the Gear icon).
- Select Miscellaneous.
- Click View Log.
2021-10-09 02:13:42: ActivePresenter 8.5.3 - 64-bit build. (Release Build: 2021.10.08) started
OS: Windows 10 (build 19043), 64-bit edition
CPU Count: 8
Hostname: LAPITRD54. Memory: 7,934 MB. Available: 2,402 MB. Memory Load: 69%
Disk Space: 237,735 MB (Free: 169,771 MB)
Project Location: C:\Users\Administrator\Documents\ActivePresenter
2021-10-09 02:13:42: TempDir: C:\Users\Administrator\AppData\Roaming\ActivePresenter\temp
2021-10-09 02:13:42: Direct3D rendering mode: hardware
2021-10-09 02:13:42: Direct3D device type: 1
2021-10-09 02:13:43: Probing audio device for playback. Error: Invalid device. Retrying with default parameters…
2021-10-09 02:13:43: Probing audio device for recording. Error: Invalid device. Retrying with default parameters
2021-10-09 02:13:43: Error while adding device to list: MME:Microphone Array (Intel® Smart : Unanticipated host error
2021-10-09 02:13:43: Error while adding device to list: MME:Jack Mic (Realtek(R) Audio): Unanticipated host error
2021-10-09 02:13:43: Error while adding device to list: Windows WASAPI:Headphones (Realtek(R) Audio): Invalid device
2021-10-09 02:13:43: Error while adding device to list: Windows WASAPI:Speakers (Realtek(R) Audio): Invalid device
2021-10-09 02:13:43: Error while adding device to list: Windows WASAPI:Jack Mic (Realtek(R) Audio): Invalid device
2021-10-09 02:13:43: Error while adding device to list: Windows WASAPI:Microphone Array (Intel® Smart Sound Technology for Digital Microphones): Invalid device
Could you please update your audio driver to the latest version and try again?
I updated the audio driver but still not working. I am using Dell PC. Is there anything that I can try.
Hi Kalana,
Can you please try removing the device named Jack Mic or any virtual audio device to see if the program works?
Dear Team
I checked after removing Jack Mic audio device but still not working. Log file attched.
2021-10-14 00:54:19: Failed to open audio stream to record. Error: Invalid device.
2021-10-14 00:54:19: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 32000. Sample Format: 2147483680
2021-10-14 00:54:19: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 8
2021-10-14 00:54:19: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 1
2021-10-14 00:54:19: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 2
2021-10-14 00:54:19: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 32
2021-10-14 00:54:19: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 2147483656
2021-10-14 00:54:19: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 2147483649
2021-10-14 00:54:19: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 2147483650
2021-10-14 00:54:20: Failed to open audio stream to record. Error: Invalid device.
2021-10-14 00:54:20: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 2147483680
2021-10-14 00:54:20: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 8
2021-10-14 00:54:20: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 1
2021-10-14 00:54:20: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 2
2021-10-14 00:54:20: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 32
2021-10-14 00:54:20: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 2147483656
2021-10-14 00:54:20: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 2147483649
2021-10-14 00:54:20: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 2147483650
2021-10-14 00:54:20: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 2147483680
2021-10-14 00:54:21: Cannot open audio recorder for displaying signal
2021-10-14 00:54:32: ---------------------LISTING WEBCAMS------------------------
2021-10-14 00:54:32: 1. Integrated Webcam - \?\usb#vid_0c45&pid_6d1a&mi_00#6&35ebabb&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2021-10-14 00:54:32: --------------------------------------------------------------
2021-10-14 00:54:34: Probing audio device for recording. Error: Invalid device. Retrying with default parameters
2021-10-14 00:54:34: flt sample format is not supported, s16 will be used
2021-10-14 00:54:34: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-10-14 00:54:34: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-10-14 00:54:35: Failed to open audio stream to record. Error: Invalid device.
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 1
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 2
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 32
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 2147483656
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 2147483649
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 2147483650
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 2147483680
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 44100. Sample Format: 1
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 44100. Sample Format: 2
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 44100. Sample Format: 32
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 44100. Sample Format: 2147483656
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 44100. Sample Format: 2147483649
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 44100. Sample Format: 2147483650
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 44100. Sample Format: 2147483680
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 32000. Sample Format: 8
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 32000. Sample Format: 1
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 32000. Sample Format: 2
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 32000. Sample Format: 32
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 32000. Sample Format: 2147483656
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 32000. Sample Format: 2147483649
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 32000. Sample Format: 2147483650
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 32000. Sample Format: 2147483680
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 16000. Sample Format: 8
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 16000. Sample Format: 1
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 16000. Sample Format: 2
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 16000. Sample Format: 32
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 16000. Sample Format: 2147483656
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 16000. Sample Format: 2147483649
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 16000. Sample Format: 2147483650
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 16000. Sample Format: 2147483680
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 8000. Sample Format: 8
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 8000. Sample Format: 1
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 8000. Sample Format: 2
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 8000. Sample Format: 32
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 8000. Sample Format: 2147483656
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 8000. Sample Format: 2147483649
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 8000. Sample Format: 2147483650
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 8000. Sample Format: 2147483680
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 48000. Sample Format: 1
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 48000. Sample Format: 2
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 48000. Sample Format: 32
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 48000. Sample Format: 2147483656
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 48000. Sample Format: 2147483649
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 48000. Sample Format: 2147483650
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 48000. Sample Format: 2147483680
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 44100. Sample Format: 8
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 44100. Sample Format: 1
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 44100. Sample Format: 2
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 44100. Sample Format: 32
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 44100. Sample Format: 2147483656
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 44100. Sample Format: 2147483649
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 44100. Sample Format: 2147483650
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 44100. Sample Format: 2147483680
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 32000. Sample Format: 8
2021-10-14 00:54:35: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 32000. Sample Format: 1
2021-10-14 00:54:36: Failed to open audio stream to record. Error: Invalid device.
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 32000. Sample Format: 2
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 32000. Sample Format: 32
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 32000. Sample Format: 2147483656
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 32000. Sample Format: 2147483649
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 32000. Sample Format: 2147483650
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 32000. Sample Format: 2147483680
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 8
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 1
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 2
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 32
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 2147483656
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 2147483649
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 2147483650
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 16000. Sample Format: 2147483680
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 8
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 1
2021-10-14 00:54:36: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 2
2021-10-14 00:54:37: Failed to open audio stream to record. Error: Invalid device.
2021-10-14 00:54:37: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 32
2021-10-14 00:54:37: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 2147483656
2021-10-14 00:54:37: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 2147483649
2021-10-14 00:54:37: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 2147483650
2021-10-14 00:54:37: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 1. Sample rate: 8000. Sample Format: 2147483680
2021-10-14 00:54:40: Cannot open audio recorder for displaying signal
2021-10-14 00:54:40: Failed to load icon: microphone_off_64_d.png
Hi Kalana,
I am sorry but we could not find out the cause of the issue. Please try reinstalling driver again by following steps:
- Uninstall the audio driver.
- Restart your computer. (Nam Nguyen did not mention this step).
- Install the driver again.
This solution worked for some users in the past. Hope it also works in your case.
