I plugged in headphone before start the software. Then I did the Youtube video recording. However, I just CANNOT record audio from Youtube video. Instead, I only recorded sound from mouse clicking and keyboard typing. (PS: I tried different audio settings: – record microphone on/off, record system sound on/off, but none of them worked)
Hi phuongdv,
Thank you so much, the audio works fine after updating my audio driver.
Just have another two problems:
When I use extended monitor, I can’t select which screen to be recorded when using full screen mode; Even if I customized which screen to be recorded, e.g. I dragged the recorded area to cover the main screen, when it starts recording, it messed up with the screen size and only recorded part of the screen.
When I started recording, it makes my PC extremely slow. (I have used NVIDIA high-performance graphic processor for this program).
The attached is my log.
Blockquote
================================ 2018-05-07 07:57:40: ActivePresenter 7.2.3 (Release Build: 2018.04.20) started OS: Windows 10 (build 16299), 64-bit edition. Version: 10.0 - 64 bit CPU Count: 4 Hostname: DESKTOP-HREVCNB. Memory: 12,186 MB. Available: 5,356 MB. Memory Load: 56% Project Location: C:\Users\haiha\Documents\ActivePresenter\ Disk Space: 487,191 MB (Free: 263,982 MB) 2018-05-07 07:57:41: TempDir: C:\Users\haiha\AppData\Roaming\ActivePresenter\temp 2018-05-07 07:58:28: flt sample format is not supported, s16 will be used 2018-05-07 07:58:28: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. 2018-05-07 07:58:28: Preparing to record audio from: Speakers (Conexant SmartAudio HD). Channel: 2. Sample rate: 48000. Sample Format: 8 2018-05-07 08:01:20: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080) 2018-05-07 08:01:20: Video Codec: flashsv. Expecting FPS: 30.00 2018-05-07 08:01:21: Video will be recorded to: C:\Users\haiha\Documents\ActivePresenter\.ActivePresenterCachedProjects\Untitled_tempdir\video_20180507_08-01-21.mkv 2018-05-07 08:01:21: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. 2018-05-07 08:01:21: flt sample format is not supported, s16 will be used 2018-05-07 08:01:21: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. 2018-05-07 08:01:21: Audio 2 will be recorded to: C:\Users\haiha\Documents\ActivePresenter\.ActivePresenterCachedProjects\Untitled_tempdir\audio_20180507_08-01-21.wav 2018-05-07 08:01:21: Preparing to record audio from: Speakers (Conexant SmartAudio HD). Channel: 2. Sample rate: 48000. Sample Format: 8 2018-05-07 08:02:07: Stop video recording. Frames recorded: 657. Dropped: 69. Duration: 42475. Average FPS: 15.44 2018-05-07 08:02:07: Recorded video data size: 52156 KB 2018-05-07 08:02:07: ProcessRecordedAudio: duration (ms) 42543.854000 2018-05-07 08:02:10: RLMedia: Estimating duration from bitrate, this may be inaccurate 2018-05-07 08:02:11: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. 2018-05-07 08:02:11: RLMedia: Estimating duration from bitrate, this may be inaccurate 2018-05-07 08:02:11: Audio Decode Stats: Process 62.000000, Wait 0.000000 2018-05-07 08:02:11: Audio Encoding Stats: Process 20.000000, Wait 52.000000 2018-05-07 08:02:11: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. 2018-05-07 08:02:11: Audio Decode Stats: Process 107.000000, Wait 0.000000 2018-05-07 08:02:11: Audio Encoding Stats: Process 31.000000, Wait 96.000000 2018-05-07 08:02:30: Preparing to play audio to: Speakers (Conexant SmartAudio HD). Channel: 2. Sample rate: 48000. Sample Format: 8 2018-05-07 08:02:30: RLMedia: Estimating duration from bitrate, this may be inaccurate 2018-05-07 08:02:30: RLMedia: Estimating duration from bitrate, this may be inaccurate 2018-05-07 08:02:41: RLMedia: Estimating duration from bitrate, this may be inaccurate 2018-05-07 08:02:52: Preparing to play audio to: Speakers (Conexant SmartAudio HD). Channel: 2. Sample rate: 48000. Sample Format: 8 2018-05-07 08:02:52: RLMedia: Estimating duration from bitrate, this may be inaccurate 2018-05-07 08:02:52: RLMedia: Estimating duration from bitrate, this may be inaccurate 2018-05-07 08:25:01: ActivePresenter 7.2.3 (Release Build: 2018.04.20) shut down
Hi @phuongdv,
Thank you for your help!
Another question: Is there a way to shorten the time when exporting the video? (I exported to wmv. format, which is the smallest size and it usually takes me the same amount of time as or longer than the length of the original video).
Haihan
If your PC has a strong CPU and a weak graphics card, you can select Start Page > Preferences > Miscellaneous > Use software rendering instead of GPU rendering.
P/S: Please create a new question instead of commenting in this thread if you have other issues.
This is really helpful. I couldn’t hear any sound from ActivePresenter if I plugged my earphones in after starting AP. Now I know: earphones first, AP second.
I have been having issues with audio files not having any sound recorded. And my case is different from this because I have no headphones connected. I have emailed my log file to the support team. Let me know what s wrong. thanks.
