Problem: I was recording my screen earlier this morning, however, my laptop suddenly turned off. I already recovered the video and the audio file however the audio file has no sound. After I pressed the record button earlier, I made sure that there is an audio recording for my video, I verified that and saw in the video I recovered that I did check if the audio was recording. However, the audio file I recovered now has no audio coming out. Pls help me.
ActivePresenter version: ActivePresenter 8.0.6
OS: Windows 10
Notes: 2021-11-22 13:01:22: ActivePresenter 8.0.6 (Release Build: 2020.04.28) started
OS: Windows 10 (build 19042), 64-bit edition. Version: 10.0 - 64 bit
CPU Count: 8
Hostname: DESKTOP-DD6TVVN. Memory: 16,221 MB. Available: 11,283 MB. Memory Load: 30%
Project Location: C:\Users\NSA - CADET\Documents\ActivePresenter
Disk Space: 243,202 MB (Free: 164,115 MB)
2021-11-22 13:01:22: TempDir: C:\Users\NSA - CADET\AppData\Roaming\ActivePresenter\temp
2021-11-22 13:01:22: Direct3D rendering mode: hardware
2021-11-22 13:01:22: Direct3D device type: 1
2021-11-22 13:01:34: flt sample format is not supported, s16 will be used
2021-11-22 13:01:34: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-11-22 13:01:34: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-11-22 13:01:42: flt sample format is not supported, s16 will be used
2021-11-22 13:01:42: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-11-22 13:01:42: Preparing to record audio from: Microphone Array (Intel® Smart Sound Technology (Intel® SST)). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-11-22 13:01:43: flt sample format is not supported, s16 will be used
2021-11-22 13:01:43: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-11-22 13:01:43: Preparing to record audio from: Microphone Array (Intel® Smart Sound Technology (Intel® SST)). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-11-22 13:01:52: flt sample format is not supported, s16 will be used
2021-11-22 13:01:52: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-11-22 13:01:52: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-11-22 13:01:56: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1366, 768)
2021-11-22 13:01:56: Video Codec: flashsv. Expecting FPS: 30.00
2021-11-22 13:01:56: Video will be recorded to: C:\Users\NSA - CADET\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\video_20211122_13-01-56.mkv
2021-11-22 13:01:56: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-11-22 13:01:56: flt sample format is not supported, s16 will be used
2021-11-22 13:01:56: Audio 2 will be recorded to: C:\Users\NSA - CADET\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20211122_13-01-56.wav
2021-11-22 13:01:56: Preparing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-11-22 13:02:00: Waiting to start in 3485
