I’ve found that I often run into these two audio issues whenever I use ActivePresenter:
- Since I’m in home office much more often, I often have remote calls while I’m working on a project and I have to add or remove an audio device (e.g., a USB headset), which causes AP to complain. Can this restriction be removed?
- When editing spoken audio in a project, I frequently have to remove breathing noises, which I usually do with “Adjust Volume” and lowering it to 5%. It’s very hard to hit a specific number with the slider, which slows it down. But doing it 100 times in a project is very, very slow. Would it be possible to add a “preset” so that I could change it to 5% (or 10% or whatever) with just a single click?
Thanks!
