Multiple quizzes in a single project
Problem: I am trying to build a project with multiple sections, each with their own quiz. We want to make it so that each section has to be completed before moving onto the sext section. The problem here is that it calculates all quiz questions for the entire project when determining a pass/fail result for a section quiz. Additionally, we need to be able to have the individual quizzes rewritten without clearing all previous quizzes.
I’m thinking that I could build a customized section quiz results page that only allows you to proceed to the next slide if you have xx number of correct answers thus far in the project, but so far, I haven’t figured out how to do this.
Here is a breakdown of requirements:
  • 8 sections, each with a quiz
  • Each quiz is between 4-6 questions
  • A score of 100% is required to pass each quiz
  • Each quiz needs the option to be rewritten without affecting previous quiz results
ActivePresenter version: 10.1.1
OS: Windows 11
Notes: I am pretty new to Active Presenter (and LMS creation in general) so specific details are helpful!
Thank you!
Hi Ryan,
Welcome to the ActivePresenter Community, and thank you for your first post!
You can achieve this by creating separate score variables for each section and handling the quiz logic manually. Please follow these steps:
  1. Create Number variables for each section to store the number of correct answers, for example:
  • score_part1
  • score_part2
  • score_part3
    Set the default value of each variable to 0
  1. On the On Load event of the first slide in each section, add an Adjust Variable action to set the corresponding score variable back to 0.
    If learners only need to retake the quiz questions without revisiting the content slides, you can place this action on the On Load event of the first question slide in that section instead.
  2. For the question slides:
    • Set Attempts to Infinite for the questions.
      You can do this via View > Object Settings, select a question, and set Attempts to Infinite. This setting will be applied to all newly added questions afterward.
    • On the On Load event of each question slide, add a Clear User Input action.
    • Configure the question actions as shown in the attached screenshots.
  3. On each section result slide:
    • Set the Next and Retry Quiz buttons to be initially hidden.
    • Add the actions shown in the attached screenshots to the slide’s On Load event and the buttons’ On Click events.
Please refer to the attached sample project for a complete example.
Multiple_quizzes_in_project.approj (1.5 MB)
We hope this helps. Please let us know if you have any questions.
Hoa
Thanks Hoa!
That’s working out quite well and functions as needed!
Bạn có thể làm một video hướng dẫn không ạ. Cảm ơn bạn
Hi @Tuyet,
Thanks for your suggestion.
For now, please have a look at the sample project I shared in my previous reply, as it demonstrates the setup and should help you get started.
We’re also working on a video tutorial for this topic, but it isn’t ready yet. We’ll share it as soon as it’s available.
Thank you for your patience!
Best regards,
Hoa
Dear Hoa,
I’m also trying to add multiple quizzes to my project and would like to keep independant scores for each quiz.
I downloaded your example approject file to see how it works. The problem that I have with this approach is that the built-in way of setting scoring values per question is no longer automated, but you will have to do that manually.
I would much rather have a simple command to reset %apQuizScore%.
Is that possible?
Hi Koen,
Unfortunately, it’s not currently possible to reset the %apQuizScore% variable directly.
We understand that this would make it easier to manage multiple quizzes with independent scores in the same project. This functionality is planned for an upcoming update.
Thank you for your patience and understanding!
