Moving a block of timeline objects vertically
Is there a quick way to move a block of selected objects (not a group) vertically in between other objects? For example I have 5 objects at the top that I want to move directly into the space below (a). I can select all 3 objects in the middle and type Ctrl-Home to move them out of the way (b), but I still have to move each of the 5 blocks one by one and line them up manually (c).
Hi Charles,
Unfortunately, ActivePresenter currently does not support dragging a block of selected objects vertically on the Timeline. Keyboard shortcuts such as Ctrl+Home or Ctrl+PgDn,… may help a little in this case. We have added this feature to our to-do list and will consider implementing it in future updates to improve usability and overall performance.
Best regards,
Hang
Awesome, that would be great!
