Move Objects in Presentation
Hello,
Is it possible to create a slide where objects can be moved about in presentation mode?
Wima
Hi Wilma,
Yes, it’s possible to let objects move in a slide.
To do that, you can add motion paths to objects to create their movements.
Here are some samples for your reference:
Tuyen
