It would be great if you had a feature that allows you to set a starting postion for an image and while moving it to a new position, you can have it resize to a new size. There are many times where i need the image to appear large at the starting point, then move and resize to a smaller size. At the ending point the image would be the smaller size. Also… when dragging the play head it would be nice to be able to see the image move when using the animate feature.
I am not sure that this feature should be added into ActivePresenter. Can you please take a look at Saola Animate? It is also an our product which has advanced animation capabilities. We will allow integrating Saola Animate content into ActivePresenter project in the future release.
