Problem: Is there a way to create slides so that text boxes or shape items can be moved around the slide area when being viewed by the individual watching the tutorial?
ActivePresenter version: 8.3.2
OS: Windows 10
OS: Windows 10
Hi Gene,
Do you mean “automatically” the objects move while the slide plays? In that case, you probably want to use Custom Motion Paths. This video should help: https://youtu.be/sIlGKAkvE48 .
Or, do you mean objects the user can move themselves? In that case, you can go to the Interactivity properties pane, and in the Drag-n-Drop subcategory you can make the object a Drag Source. Make sure you uncheck the Revert checkbox; otherwise, the object will always jump back to the original position.
Hope this helps.
Cheers,
Keith
Thank you for your response. I meant the second of your 2 options. I set it up as you suggested and it works great. Thank you again for your time!
