Problem: Have mouse clicks area setup on slide that never advances. Mouse click area works fine 3 times. Then does not work anymore. Events hide objects and then show 1 object and continue presentation. Use Tutorial mode.
Please change the Attempts value in your Mouse Click’s Properties pane.
The default value is 3 but you can change it to Infinite.
By doing so, there is no limit to the number of attempts that users could make.
In addition, if you want to make a menu, Shape object will be better for using instead of Mouse Click.
Thank you for your response.
That looks like it should work and I will review the other option also.
Another item that I have, is it possible to have a cursor path directed to 1 location, stop as if the cursor has pressed an icon, then wait 2-3 seconds and then have the same cursor path directed to a second location and then press another icon on the same slide? I think I see that you can only save 1 cursor path per slide.
If I have to send you my project where would I upload it to?
Thank you again for your response.
You can upload them to a cloud storage site like Google Drive, then send the download link to us here, or through our email address: support@atomisystems.com.
That solution worked fine. I still have the question about the cursor path that I detailed above. Should I start a new topic for that?
Thank you for your resonse.
