Problem: Hi, I want to change default mouse click attempts to infinite. Can I do that? If not, Is there any way to apply infinite setting to one mouse click and then apply the same to all?
ActivePresenter version: 8.3.0
OS: WIN10
OS: WIN10
Hi Shri,
You can change the default mouse click attempts in Object Settings. After that, you can save the project as a custom theme to reuse these settings when recording or creating new projects from this theme.
For detailed information, please see this tutorial:
Thanks a lot, ToanLS. It helps
