More precise audio volume setting
When you often change volume for background music (when narrator speaks), using of volume fader could be inconvenient, especially if you would like use this same specified volume value for all ranges with lower background music. What do you think about adding option for manually typing volume value e.g. after double click its value on fader pop-up, or optionally about longer fader (maybe it allows on more precise volume setting)?
Janusz
Hi Janusz,
I am not sure that I understand this correctly. How about using Adjust Volume, Audio Normalization instead of this? Am I missing something?
