Problem: My course is over 200 slides. I want to merge them in batches, making it easier to do final edits. Is this possible?
I copied a few, 3-4, and started another project to practice. The practice went well, but it didn’t go well when I tried with the course.
First, I merged about 25 slides and replayed them; the sound was there, but the images were not visible on some. I noticed they were short, so I lengthened those slides, but that did not help. Then, I reduced the number of drops in the batch, but they merged with the initial set.
In another attempt to resolve my issue, the program batched the entire course, so I wondered what would happen. The file is so large the pictures would not load, so I inquired about the batching process. I am no tech genius, but I think you will suggest shrinking the file, so what would be the best way to do this and maintain the integrity of the result? (frame size and whatever else I don’t know about) I hope I am not outside of the scope of what the program does. Please help me move this forward.
I tried to be as transparent as possible; thank you for your patience.
ActivePresenter version: 8
OS: Catalina 10.15.7
