Hi there,
Can someone tell me how to merge audio snippets while filling the gaps between the snippets with silence?
Thank you so much
Hi there,
Thank you so much
Hi Felix,
Normally, if you join audio objects, the space between them will be removed, and no silence is created.
However, you can try doing this trick to see if it addresses your concern.
If you have multiple audio objects, repeat steps 1 and 2 before selecting all of the audio objects and joining them together. By doing so, the silent gaps will be filled between them.
Kindly see the quick steps in the attached video:
That works perfectly, thank you!
