is it possible to define Object States for questions through JS?
For instance, let’s say I have a text entry question to simulate a login field in a computer. Once the login was successful, the text entry question should go to the state ‘Solved’, which would then show the computer screen after login and nothing of the fields and buttons of the question.
I know there are different ways of doing that but I am specifically interested in a solution that involves object states.
It doesn’t seem so, since the placeholder itself seems to be without a state, but I wanted to ask anyway.
Thanks, Rolf
