Is there a simple way to make it mandatory to use all drag objects for a drag and drop question to submit as complete?
I have 9 drag objects and 4 landing boxes and I want Submit to go to incomplete as long as not all the 9 items are in place - knowing that my boxes accept 3 then replace.
For the moment it goes to incomplete only if I don’t use any drag items
Is there a simple way to do this?
I think I could use events and variables but I believe they may be an easier way I cannot see.
Thanks,
Michael
Hi Michael,
Here are steps to do that:
- Create a True/False variable for incomplete action.
- Run javascript when the question is submitted to see if it’s complete or not and update the variable.
- Show incomplete feedback if the question is incomplete and show correct/incorrect feedback if it’s complete.
You can see this sample for more details: complete_all_drags.approj (232 KB)
Best regards,
Hang
Works great! Thanks a lot!
