Make hidden animated text visible and running
Hello,
I create an interactive video where I have on one slide three actions. While running the video, first a button appear which stop the presentation (Thank you Hang) :wink: switch to another video and came back to the main video, second button the same with a gif, but now…
the third one should be an animated text like explained here: How to Create Text Typing Animation in ActivePresenter 9 but I´ve to hide the Text Caption field, it should appear only by click the third button. It appears as well, but the text is not longer animated. Is there a trick to animate the text after unhide the Text Caption?
Thanks a lot and a good weekend :innocent:
Hi Oliver, it’s been a while! :grin:
You can try using an Interactive Timeline for this. Just add an entrance effect and text animation to the Text Caption. Then, for Button 3, add the “Start Timeline” action.
Hope that helps!
Hello Hang, thank you for this great tip. I will try it out. All the best to you and have a great week. :star_struck:
