Hello,
I think i know the answer but am asking to be sure.
My question, how can i create a magnifier effect under the cursor?
here is a pic example:
and a YT example: DaVinci Resolve 17 Edit Training - Introduction to Editing Part 1 - YouTube
thanks!
Hi there,
At the current time, ActivePresenter hasn’t supported magnify cursor effect.
But you can consider using the Zoom-n-Pan feature to zoom in or zoom out a particular part of the screen.
Please check out this quick video tutorial for more information:
Kind regards,
Thank you, Thuy.
Zoom-n-pan is very good. i have used it. Functionally they are the same.
Aesthetically, a round shape is pleasing to viewers. Additionally, zoom displays only the zoomed image while magnify also displays outside the magnified area.
