Hi. Is it achievable just to repeat a symbol animation after the main timeline ended. Which means after the audio and video in the main timeline has ended, the symbol animation keeps playing over and over again. This is achievable with gif but I want to know if it can be recreated inside Saola animate. Thanks
Good afternoon,
Yes, it is possible to loop the symbol after the main timeline ends.
Please take a look at the attached sample for details:
loop-symbol.saolapack (3.4 KB)
First, in the symbol > add a timeline trigger at the end of animation in the Timeline > select Start Timeline action.
Next, go back to the main editor > insert a Timeline Trigger > add Start Symbol action.
You can refer to this tutorial for more helpful information:
BR,
