hey there developers, I have a problem: when I import a PowerPoint to Active Presenter, the animations don’t get linked and when I start the HTML, clicking the actions set on PowerPoint does not do anything.
Active Presenter version:
9.0.7
OS:
Windows 10
For your information, after importing PowerPoint presentations into ActivePresenter, all the slides including animations will be opened with the Click Sequence timeline.
Please take a look at the tutorial below first:
Then, describe your issue in more detail to help us understand what you’re facing. A short video illustrating your case is appreciated.
Besides, kindly send your PowerPoint presentation to our email support@atomisystems.com.
We’ll check it and get back to you.
